Missing Edit & Add Function on Modules to Entire Site
Last Post 2010-03-18 05:14 PM by Joseph Craig. 3 Replies.
JackoUser is Offline
2010-03-18 02:25 PM
Just logged into my DNN site as host and noticed I can no longer edit modules or access the settings popup menu on all modules on all pages. The actual page settings menu is visable and I can add new pages. I've tried to add a new module but this is also not functioning. Tried on different browsers but still no luck. Tried changing the SKIN to default and no luck. Restarted the DNN site but no luck. Reset permissions to entire dnn directory but no luck Very stange and very worrying, can anyone please suggest what may be wrong
2010-03-18 03:22 PM
Strangely enough the Admin account is displaying the modules settings menu. To confirm its the menu where you mouse over to modify that particular modules settings on that page. Why would the host account stop displaying these menus?
2010-03-18 03:31 PM
arrrrggghhhh for goodness sake, I was in View mode!. After a year working on numerous B2B DNN sites I've never noticed or used that option, don't I feel like the fool. Thanks Joseph http://www.dnncreative.com/Forum/ta...fault.aspx
Joseph CraigUser is Online
2010-03-18 05:14 PM
Glad it's working!
DNN 6.2 by Sameer
RE: Deploying dnn by Sameer
Thanks a lot so kind of you
I'm confused by this, too.
We are running DNN 6.x
