Background Music
Last Post 2010-03-21 09:37 PM by BCRose. 3 Replies.
KyleUser is Offline
2010-03-18 06:44 AM
Do you know of any module that I can use to play background music on a single page?  Or do you have a recommend method to play the background music?
cyboramaUser is Offline
2010-03-19 03:16 AM
Hello Kyle I can't think of any modules that could do this though that doesn't mean they are not out there.
What I would try if I were you if you just want background music to play on a page without a lot of pizaaz is just to simply instantiate an html module on the page you want the background music to start playing and than click on EDIT CONTENT and go up to the toolbar icons that show up and click on SOURCE. Now you can just simply type in some good old fashion object and embed tags with the file you would like to have play using appropriate parameters such as AUTOSTART, LOOP, etc... Than click on update to update your html you added to the module and I would suspect it would play once these were loaded.
There may be a more resourceful way of doing this but if it is only one page you are really looking for this to be on opposed to say several than this should do it.
Bo
Joseph CraigUser is Online
2010-03-19 12:04 PM
That will work.
BCRoseUser is Offline
2010-03-21 09:37 PM
Onyatech has a good module for this.
DNN 6.2 by Sameer
RE: Deploying dnn by Sameer
Thanks a lot so kind of you
I'm confused by this, too.
We are running DNN 6.x
