Non Standard Port with DNN 5+
Last Post 2010-03-17 03:10 PM by Joseph Craig. 1 Replies.
AdrianUser is Offline
2010-03-17 12:31 AM
Hello Some time back we started tinkering with DNN v5, however we couldn't get it to work when trying to deploy using a non-standard port (ie. not port 80) Were there any tricks involved to get this to work? Using DNN 4.9.5 on a non-standard port seems to work fine, without having to "do anything extra"
Joseph CraigUser is Online
2010-03-17 03:10 PM
In web.config ... "set UsePortNumber to true to preserve the port number if you're using a port number other than 80 (the standard)"
You may also have to use the port number in the portalalias table -- my memory is inconsistent on this point.
DNN 6.2 by Sameer
RE: Deploying dnn by Sameer
Thanks a lot so kind of you
I'm confused by this, too.
We are running DNN 6.x
