Home Page Login Question
Last Post 2010-03-14 05:43 PM by BCRose. 4 Replies.
BCRoseUser is Offline
2010-03-13 04:40 PM
I would like to remove the 'LOGIN' text from the top right of my pages.   How can I do this?   I tried removing any reference to 'login' in the stylesheet editor but that didn't seem to do anything.
Any help would be appreciated
Monte
Joseph CraigUser is Online
2010-03-13 04:43 PM
The LOGIN and REGISTER links are Skin Objects that are included in your skin file. The easiest way to remove them is to edit your skin file.
It is also possible that your skin wraps these objects in a named div tag. If that's the case, you can style that div for display:none to remove it without editing your skin file.
2010-03-13 04:56 PM
Thanks for the quick reply.
Sorry for being a dummy but where do I edit a skin at? Or the style sheet for the skin?
2010-03-14 05:29 PM
Start with:
Then move on to some of the other skinning tutorials.
2010-03-14 05:43 PM
Thanks Lee...I have been watching the videos. Lot's to learn here.
DNN 6.2 by Sameer
RE: Deploying dnn by Sameer
Thanks a lot so kind of you
I'm confused by this, too.
We are running DNN 6.x
