Using Default Template for Pages
Last Post 2010-03-24 02:39 PM by WinXnet. 1 Replies.
Todd RenierUser is Offline
2010-03-12 05:07 PM
I have a default template that I would like all Admins to use when creating new pages. I would also this template to be the only template for each portal. I would like to gray out the template box "Template Folder" and "Page Template" or apply the default template. We have some modules like the console and one html module that are host edit only modules applied to every page in the same location. We would like this template to be applied every time a Admin creates a new page.. Todd
WinXnetUser is Offline
2010-03-24 02:39 PM
you should be able to create a page template and put it in the templates folder.
Then just remove or replace the "Default" template. Move a copy of the default template first just to be sure.
You can also create a Portal template (say a 3 to 5 page starter site).
GeishaMX ^_^
http://www.winxnet.com Emerson Bruce - http://chayadigital.wordpress.com
DNN 6.2 by Sameer
RE: Deploying dnn by Sameer
Thanks a lot so kind of you
I'm confused by this, too.
We are running DNN 6.x
