OWS Query Template Results
Last Post 2010-03-11 08:07 AM by Vicky Swift. 2 Replies.
Vicky SwiftUser is Offline
2010-03-05 11:24 AM
Hi I'm a real newbie at OWS and have been working through the tutorials - I felt confident to have a go myself but have got really stuck on something that I am sure is trivial / obvious. I have a Query template with the following SQL statement on it SELECT FieldTitle,FieldValue,UserDefinedRowID FROM UserDefinedData JOIN UserDefinedFields ON UserDefinedData.UserDefinedFieldID = UserDefinedFields.UserDefinedFieldID WHERE UserDefinedRowID IN (SELECT UserDefinedRowID FROM UserDefinedData JOIN UserDefinedFields ON UserDefinedData.UserDefinedFieldID = UserDefinedFields.UserDefinedFieldID WHERE UserDefinedRowID IN (SELECT UserDefinedRowID FROM UserDefinedData JOIN UserDefinedFields ON UserDefinedData.UserDefinedFieldID = UserDefinedFields.UserDefinedFieldID WHERE FieldTitle = 'Non' AND cast(FieldValue as nvarchar(max)) = 'True' ) AND (FieldTitle = 'MI' AND cast(FieldValue as nvarchar(max)) = 'True') ) AND (FieldTitle = 'Name' OR FieldTitle = 'Link' OR FieldTitle = 'Notes') ORDER BY UserDefinedRowID I then display the results from this using a detail template
[FieldValue]
This works fine. Now I would like to manipulate the way the data is displayed. So for example take the [FieldValue] from several rows of data and display these in one row in the detail template. I have spent a lot of time trying to do this and am going around in circles - can anyone help Thank you
KA-NAUser is Offline
2010-03-11 07:07 AM
I don't know, that is possible, but I would try to use javascript in dteial template to build string and then use it in footer template.
2010-03-11 08:07 AM
Hi, In the end I achieved what I needed with IIF statments and ALTERNATE Pretty sure its not the neatest solution - but it does what I need.
DNN 6.2 by Sameer
RE: Deploying dnn by Sameer
Thanks a lot so kind of you
I'm confused by this, too.
We are running DNN 6.x
