create custom permissions for modules
Last Post 2010-03-04 09:55 PM by Joseph Craig. 1 Replies.
marbabUser is Offline
2010-03-04 06:58 PM
Can you please help me in finding out how to create custom permissions for modules. As we have 'Edit', 'View' permissions of registered, subscribed, unauthenticated users. How can i add my own custom permission check here like 'premium subscriber'.
Thanks.
2010-03-04 09:55 PM
The simplest answer is that you first need to create new security roles.  Then you will be able to give module permissions to the new roles.  We have tutorials about security roles:
The "professional" version of DotNetNuke has an enhances set of permissions related to security roles.  If you want them, but don't have the Professional version, there is a free provider at oliverhine.com.
DNN nav issue by imran shaikh
