Change linkclick to document name
Last Post 2010-03-09 09:02 PM by WinXnet. 5 Replies.
Mike FlowersUser is Offline
2010-03-04 11:33 AM
Does anyone know how to make links to documents appear with the document name/path instead of linkclick? In my previous version of DNN (4.8.3) when the user linked a file on the site the link appeared as /portal/0/filename.PDF now since upgrading to 5.2.2 it is appearing as /LinkClick.aspx?fileticket=I5c8f0bk4Pw%3d&tabid=78. The user does not need the files to be secure. The problem is that when the link is copied from the website to an email using a MAC the link in the email appears as a very ugly
+ Promotional Supplement 2010>
http://www.domain.com/LinkClick.asp...d&tabid=78
It seems that in DNN5 links between pages are now friendly names but file links are not. Is there a configuration setting (or any other way) to change this?
2010-03-04 10:02 PM
When you create the link, do not check the box to track the number of times the file is opened. That should do it.
2010-03-04 10:34 PM
That was what I asumed but the tick box is off by default and I have not activated it. To check that my site was not corrupt in some way I have installed a new website using 5.2.3. This does exactly the same. Linking to a page works fine but linking to a file always seems to use linkclick. There must be some config change to make it use the path and file name; problem is I cannot find how. PS I have not misspelt asumed but when I spell it correctly it ends up on the post as umed, the profanity checker is a bit aggressive!
2010-03-05 10:21 AM
I've checked this, and I have the same problem, I also cannot find a way to turn off that setting.
The only way you're going to get around this at the moment that I can see is to type in the URL directly.
Thanks for the tip on the profanity checker - it has recently being implemented after someone decided to "test" if we had one. - I will make sure you can use a s sume!
2010-03-05 01:48 PM
Whoops.  I was confusing file names with page names.
WinXnetUser is Offline
2010-03-09 09:02 PM
as far as I know, there is no way to not use linkclick other than to hard code the long url
Select link text
click on link button
Link info tab: type in long link url ( just like any external url, you need to know the actual location in your site structure of the file, Ex: http://winxweb.com/Portals/0/Docume...mydoc.pdf)
Target tab: select "_blank"
Emerson ^_^
http://www.winxnet.com Emerson Bruce - http://chayadigital.wordpress.com
informative!!!
informative!!!
