DNN Blog 4.0 Question
Last Post 2010-03-03 02:43 PM by Lee Sykes. 4 Replies.
jasonlevanUser is Offline
2010-03-03 06:14 AM
Lee, I viewed your Blog setup videos. This senario does not seem to work with the new DNN Blog 4.0 RC. It seems now that when you set the 'Personal Blog' setting on the View_Blog module, the permalinks will still link back to the origional TabID where the blog is first added. This means if you restrict the main Blog page as you did in your video, the individual 'Personal Blog' pages will not be able to open the blog entry. I also saw a PK issue in Blog_Settings table preventing the installation of blog components to multiple pages. Can you confirm this behavior? Thanks, -Jason
2010-03-03 11:52 AM
Where have you downloaded this version from? I can only see version 3.5.1 on the dotnetnuke projects downloads page.
As this is a RC, I would suggest you contact the blog team direct and ask if this is a bug or intentional? There is likely to be a few bugs left in the module in the RC version.
2010-03-03 02:25 PM
Here you go Lee. http://dnnblog.codeplex.com/releases/view/40189 It is supposed to be RC but I am finding many bugs. There does not seem to be many people testing it. -Jason
2010-03-03 02:28 PM
Here an interesting thread. http://www.dotnetnuke.com/Community...fault.aspx -Jason
2010-03-03 02:43 PM
If you are wanting functionaility like that thread I would use www.ventrian.com News Articles module. It can cover all that you need from a blog and more.
I would steer clear of a RC version as they usually still do have a lot of bugs
