Simple OWS question ("direct link" to single record)
Last Post 2010-02-23 08:26 PM by Justin Beitler. 1 Replies.
Justin BeitlerUser is Offline
2010-02-22 09:51 PM
Just wondering if anyone knows a way to p  information from the web address to a variable in OWS (so for example, I could make a link "http://www.mywebsite.com/ows?=455" which would, in turn, reveal an OWS page that would "Select * from TABLE where ID=455") Not really sure how to do this, so any help is greatly appreciated!!
2010-02-23 08:26 PM
Nevermind.. Figured it out (gosh that was simple...)
For anyone curious, if you add a parameter to your URL (such as ?ID=12345) then you will have access to the "querystring" variable in OWS (so for example you can make a call to [ID,Querystring] and it will return '12345'
Yes.. Basic... Whoops...
