ows disable enter key
Last Post 2010-02-22 06:28 PM by Deb Herman. 2 Replies.
Beth LancasterUser is Offline
2010-02-22 05:09 AM
In the OWS Knowledgebase tutorial - Search page, the user must click on the search link to perform the search. However if the user presses the enter key it is unclear what is happening but a page on the site is selected and displayed. I'm not clear on how it decides what page to go to. I want to prevent this from happening since it is not unusual for the user to press enter. Would appreciate any help or point me to an example. Thanks.
Paul DeschenesUser is Offline
2010-02-22 04:33 PM
Beth,
At this point, OWS leaves off in it's capability and you get into using traditional javascript web techniques to accomplish what you want.
Try searching Google for "enter key javascript" and there are various options for disabling the Enter action as well as enabling the Enter action to do the search.
Paul Deschenes
DNN Creative OWS Tutor
Deb HermanUser is Offline
2010-02-22 06:28 PM
I figured it would be a javascript function. I've tried a couple of things but without success. I put the following code in the - on load -  ignment control header withe scrip tags of course.
script type="text/javascript"> function noenter() { return !(window.event && window.event.keyCode == 13); }
in the search input field i put onkeypress="return noenter()"
What happens is that is goes to the admin module edit for an html module I have on the same page. Seems like maybe DNN is grabbing the enterkey before I do. Would love some help. Not necessarily the detail code (would be nice) but the general steps or sugesstions to make more user friendly. Thanks
