Database after backing it up with SQL 2008
Last Post 2010-02-18 07:06 AM by Lee Sykes. 4 Replies.
freddymoralesUser is Offline
2010-02-16 08:35 PM
hello mr.Lee I am going thru your videos very well. Thank you! If I have a problem, I usally find a solution on blogs. but after I attached and backed up my DNN database, I can no longer visit my local DNN anymore. I know your tutorials talk about this, and I did the web.config editing, and still can not get it to view my local site, can you help me please? also i just noticed there is not database in my local files after attaching the DB to SQL fmorales
2010-02-17 07:45 PM
When you attached your database to SQL Server can you login to SQL Server using Management Studio and view all of the tables and data?
Did you setup a username and password to access the database?
What are the details you entered into your connection string?
2010-02-18 07:00 AM
<!--[if gte mso 9]> Normal 0 unctuationKerning/> false false false oNotPromoteQF/> EN-GB X-NONE X-NONE ontGrowAutofit/> ontVertAlignCellWithSp/> ontBreakConstrainedForcedTables/> ontVertAlignInTxbx/> MicrosoftInternetExplorer4 <!-- /* Font Definitions */ @font-face {font-family:"Cambria Math"; panose-1:2 4 5 3 5 4 6 3 2 4; mso-font-charset:0; mso-generic-font-family:roman; mso-font-pitch:variable; mso-font-signature:-1610611985 1107304683 0 0 415 0;} @font-face {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4; mso-font-charset:0; mso-generic-font-family:swiss; mso-font-pitch:variable; mso-font-signature:-520092929 1073786111 9 0 415 0;} @font-face {font-family:Verdana; panose-1:2 11 6 4 3 5 4 4 2 4; mso-font-charset:0; mso-generic-font-family:swiss; mso-font-pitch:variable; mso-font-signature:-1593833729 1073750107 16 0 415 0;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-unhide:no; mso-style-qformat:yes; mso-style-parent:""; margin:0cm; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman","serif"; mso-fareast-font-family:Calibri; mso-fareast-theme-font:minor-latin;} .MsoChpDefault {mso-style-type:export-only; mso-default-props:yes; font-size:10.0pt; mso-ansi-font-size:10.0pt; mso-bidi-font-size:10.0pt;} @page Section1 {size:612.0pt 792.0pt; margin:72.0pt 72.0pt 72.0pt 72.0pt; mso-header-margin:36.0pt; mso-footer-margin:36.0pt; mso-paper-source:0;} div.Section1 {page:Section1;} --> <!--[if gte mso 10]> When you attached your database to SQL Server can you login to SQL Server using Management Studio and view all of the tables and data?
YES
YES on both places the video tutorial told me to; please check out the pictureScreenshot I attached
<connectionStrings>
Connection String for SQL Server 2005/2008 Express -->
add name="SiteSqlServer" connectionString="Data Source=.\SQLExpress; Initial Catalog=C:\DNN_SITES\DNN_50202_TUTORIAL\APP_DATA\DATABASE.MDF;User ID=dnnxxx3;Password=xxxx" providerName="System.Data.SqlClient" />
<!--connectionStrings
appSettings>
Connection String for SQL Server 2005/2008 Express - kept for backwards compatability - legacy modules -->
add key="SiteSqlServer" value="Data Source=.\SQLExpress; Initial Catalog=C:\DNN_SITES\DNN_50202_TUTORIAL\APP_DATA\DATABASE.MDF;User ID=dnnxxx3;Password=xxxx" />
Connection String for SQL Server 2005/2008 - kept for backwards compatability - legacy modules
2010-02-18 07:04 AM
Which OS are you using?
SQL Server version?
2010-02-18 07:06 AM
If you can attach any pics to the forum post, they would be useful (you can zip them if there are several) thanks,
RE: DNN 6.2 by Joseph Craig
DNN 6.2 by Sameer
RE: Deploying dnn by Sameer
Thanks a lot so kind of you
