Simple problem to resolved in OWS
Last Post 2010-02-11 03:57 PM by Lee Sykes. 1 Replies.
KA-NAUser is Offline
2010-02-10 03:58 PM
Hello, I have one simple question - how to compare two textboxes in OWS (that will be password validation)? Thanks Marek
2010-02-11 03:57 PM
Have you had a look at this tutorial?
How to Create a Custom Login Module with OWS
In Video 3 - you can also download the code for it
RE: DNN 6.2 by Joseph Craig
DNN 6.2 by Sameer
RE: Deploying dnn by Sameer
Thanks a lot so kind of you
