query regarding page options
Last Post 2010-02-09 07:11 PM by Lee Sykes. 3 Replies.
KaustavUser is Offline
2010-02-09 02:05 PM
My site will have two Home pages, one for a new visitor and one for a returning visitor.   Is there any process without registered/non-registered concept?  Can we do that via coockies?
Waiting for advice.
2010-02-09 04:03 PM
hello,
If you do not wish your visitors to login, then I think the only other option will be to use cookies. you should be able to do this using the OWS module, or by creating a custom module.
2010-02-09 04:56 PM
Thanks for your reply.
Could you please let me know from where I can get the OWS module?
2010-02-09 07:11 PM
DNN 6.2 by Sameer
RE: Deploying dnn by Sameer
Thanks a lot so kind of you
I'm confused by this, too.
We are running DNN 6.x
