Ealo Tab Localization help
Last Post 2010-02-09 07:38 AM by Sadabahar. 0 Replies.
SadabaharUser is Offline
2010-02-09 07:38 AM
hi, I have installed Ealo Core Api and Ealo tab localization and ealo Menu provider. menu is working fine with the text provided for differnt languages but Title is not working? any body can help?
