Customizing registration page
Last Post 2010-02-09 10:33 AM by KA-NA. 4 Replies.
KA-NAUser is Offline
2010-02-08 02:32 PM
Hello, Is there any possibility to custom registration form from VS2008? I need to put list with second list (user must choose language and then choose from 1 to 10 how much he nows it). Is there any possibility to do this? And one more question. I would like to set i.e. phone as unique ID. Only one account with that the same value would be accepted in DNN. Is it possible to set one field as unique ID? Regards Marek
2010-02-08 02:37 PM
You can do this without any coding.  You will want to look at:
If you need more flexibility, a third-party (commercial) module might be helpful.  And these tutorials might be appropriate:
There are other modules, too.  Look at Snowcovered.
2010-02-08 05:33 PM
Thanks for an answer.
I saw creating with OWS and I'll try it tomorrow.
First three links doesn't give me a possibility to do, what I need. I explained maybe to simple...
I need to add three records to my register form. I thought, that maybe is possible to rearange some ascx file, that one record in database will be inserted from dropdownlist and textbox.
Choose first Language [language],[|] choose score [score]
Choose second Language [language],[|] choose score [score]
Choose third Language [language],[|] choose score [score]
Maybe I set all boxes in two columns and then try to arrange them, as they will looks like lines (sign [|])
Is it possible to make changes in registration by .NET? I'm MS Developer, but I didn't found where make it
2010-02-09 12:21 AM
You can add three fields to the user profile as you describe.  No coding is required.  Look at the Manage Profile Properties link on the User Accounts page.
You can, but I don't recommend, that you start rewriting the basic code of DotNetNuke.
2010-02-09 10:33 AM
