What are best tools for localization?
Last Post 2010-02-08 11:22 PM by Joseph Craig. 3 Replies.
SadabaharUser is Offline
2010-02-08 03:46 AM
Hi, I am creating website in English and Arabic using localization. Due to different direction of languages there are some issues in different modules. I want to know what are the best tools can be used for localization of different object of the site keeping in mind the different directions of the languages. Localization need for all the object required for a page like Menus Contents Page title Page Description Skins CSS graphics
Joseph CraigUser is Online
2010-02-08 12:34 PM
Based on my limited experience, modules from Apollo and EALO seem to be the gold standard.
2010-02-08 05:54 PM
Hi Joseph, you are senior dot net nuke developer and u have develop many website in DNN and localization. Can you please tell me the module name to use for contente, menu, page title, description and especially CSS and skins localization etc...... i will be very thankfull to you. keeping in mind that the language direction is from right to left.......
2010-02-08 11:22 PM
The modules from Apollo and the EALO and Magic Content modules are the ones that I would use.  I don't have any experience with right to left languages, though, so I don't know if they will be suitable for you.
RE: DNN 6.2 by Joseph Craig
DNN 6.2 by Sameer
RE: Deploying dnn by Sameer
Thanks a lot so kind of you
