DNN Deployment Issue
Last Post 2011-06-21 04:24 PM by Joseph Craig. 31 Replies.
Page 2 of 2 << < 12
chiragUser is Offline
2011-03-04 03:28 AM
Hi Joseph,
Thanks for Your reply.Every thing is installed correctly, the thing is only the home page opens up with the portal alias as soon as I click on any other page it's start showing the original IP address( i.e. system's IP address) in the address bar; even if I delete this IP from the alias table, it automatically adds up this IP as soon as the website is reloaded or I click on page other than the homepage.
And my problem is why doesn't it show the other pages with that portal alias?
2011-03-04 03:35 AM
One more thing, Is there any way to add up more Payment Processors to the payment settings?
2011-03-04 04:27 AM
Hi Tatva,
Your and mine problem seems to be alike . All what happening to me, is same what you have listed in the post
Hi Abhishek, thanks very much for your quick response. But, prob is that i can't remove port number as on that server already another live website work. so that not work for me. one other issue that if you can solve for me. it is......... When i try to upload on my other production server.....it works fine but in case when i click on logo or register any user and click on register(i.e. when enver NavigateURL() is of DNN ) is use it redirect to other server. I mean to say...... I upload my site on say 192.168.100.200 and when run my site in live using say 152.254.256.20 it is working fine as per our setting both are interlink. But when click on logo it redirect to 192.168.100.200 as website in physically on this server. Is there any way that i can control NavigateURL() and add some setting which redirect the site to other address... I try to edit NavigateURL() function but does not work for me. Any help will be great. Thanks Amit 1.
Did you find an solution for that.
2011-03-05 01:48 PM
If the site is redirecting to another site, that usually means that there is an entry in the portalalias table that points to the other site.
There can be cases where you have links that are hard coded with the URL of the other site. You need to change those to relative links.
2011-03-07 07:51 AM
There is no such any case the URL is hard coded(those pages I am clicking on are Inbuilt pages like host settings etc. The portal alias remains correct until I click on any other page other than home page) as far as the table data is concerned, there is only a single entry which is the portal alias that I require and the other one is the actual IP of the server (on which the website is physically deployed) which is automatically added to the alias table
Also I wanted to know, how to add more payment processors to the DNN host/Admin settings?
2011-03-09 12:29 AM
Adding additional payment processors: I can't think of a way to do it without doing some custom programming.
2011-03-10 09:09 AM
Thanks for nothing
2011-03-10 01:45 PM
I assumed that your message was related to the "core" payment processors.
If you look at some of the ecommerce solutions for DotNetNuke, I believe that most of them offer additional payment processors, but these work only inside of those modules. If you are looking for a "store" or something to handle subscriptions to a website, then there are choices.
What is your specific application?
2011-03-11 08:30 AM
For my project I need to add WorldPay gateway. and want that one in the same drop down in which paypal is shown
2011-03-15 11:51 PM
In that case, you'll need some custom development.
2011-06-21 02:46 PM
Can anyone tell me that how can I restrict unregistred user from viewing my website pages means I don't want to do it seperately for each page I want to do it for all of the pages at one time
2011-06-21 04:24 PM
You will need to do this with some SQL. Check the tutorial titled How to Update the DotNetNuke Page Settings Using SQL Queries.
When you do this, you will need to modify the table TabPermission.
My suggestion is that you make a backup of your database before doing this, just in case you need to undo everything.
Page 2 of 2 << < 12
RE: Deploying dnn by Sameer
Just sent it.
