Upgraded to 5.x, the menu dissapeared and can't login - Solution
Last Post 2010-02-16 02:21 PM by gerard gillman. 23 Replies.
Page 2 of 2 << < 12
Joseph CraigUser is Online
2010-01-27 05:56 PM
gerard gillmanUser is Offline
2010-02-16 12:14 AM
remember me I one with javascript errors at home. not at work. i have fixing my website and work computers. I came across something. I was looking at the
Host settings - advance settings - performance settings.
i'm gettting this message
""** Warning: Memory page state persistence can cause Ajax issues **
do you know how I can fixed this
2010-02-16 12:26 PM
In the Performance Settings, set Page State Persistence to Page and not to Memory.
2010-02-16 02:21 PM
I did try that setting to page. it still get me that message. I sill get errors on home computers. I did try the virtual machine. but gave me errors on the virtual machine.I try with windows XP. and windows 7 on virtual machine. i am sending a help ticket to my service provider. maybe they know why. I have also try on my other computer. and gave me the same error. it weird why would work on work computer and not home computer.
any other ideas.
Page 2 of 2 << < 12
RE: Deploying dnn by Sameer
Just sent it.
