House Menu version 1.4.1
Last Post 2010-01-04 01:35 PM by Joseph Craig. 1 Replies.
mickiUser is Offline
2010-01-04 06:19 AM
another question...
is it possible to add an external link to the house menu module? sorry to ask such naive questions... i have a client who would like a link to another of his sites along with the rest of this site's links.
thank you for your help...
2010-01-04 01:35 PM
You can create a "page" that is a link to an external URL. Set this in the page settings. It will then appear in the menu and clicking the entry will take you to the external URL.
DNN nav issue by imran shaikh
