HTML/Text Custom templates
Last Post 2010-01-03 06:00 PM by gbrown. 6 Replies.
gerryUser is Offline
2010-01-03 12:32 AM
I notice the html/text module can insert templates. Can these be customized or add new ones? Also could you restrict which templease are available to the user?
Regards - Gerry
2010-01-03 02:48 AM
You can create page and portal templates in DotNetNuke.  See:
DotNetNuke Portal Templates and the Site Wizard
Configuring DotNetNuke before installation
(How to create a portal site template for the wizard)
The Text/HTML module doesn't use templates.  However, you can export a module's contents and import it into another Text/HTML module.
2010-01-03 03:12 AM
Thanks for the reply. Maybe I was unclear.
The third icon in the fckeditor has a button for inserting templates into the HTML/Text module
It is these templates I want to modify or limit
Regards - Gerry
2010-01-03 03:24 AM
Aha!  Look at this:  FCK Editor HTML Templates
2010-01-03 03:30 AM
Perfect, was using wrong search term and abit lazy to scroll through all the results due to the festive season!
Regards - Gerry
2010-01-03 03:35 AM
No problem.  Enjoy the festivities!
gbrownUser is Offline
2010-01-03 06:00 PM
The templates feature can be very handy and useful. I switched to Telerik's RADEditor mainly for it's very nice templates manager. It is much nicer than FCK's where FCK just has a single list that is the same on all pages in your portal. RAD has a templates manager much like the image manager in FCK where you can place templates in folders and control access to different types of templates.
