DNN 5.2.0 and special characters
Last Post 2010-01-03 04:43 PM by Joseph Craig. 5 Replies.
saintXUser is Offline
2009-12-31 09:07 AM
Hello, DNN 5.2.0 can not display some characters linke Ü or Ö. I know that this is a known bug of this version. Is there meanwhile any solution for this issue? Thanks
2009-12-31 03:06 PM
Does 5.2.1 address the problem?
2009-12-31 11:11 PM
I do not know about 5.2.1 Joe. If I don't find a solution for 5.2.0 then I will have to upgrade 3 websites :-( Thanks
2009-12-31 11:38 PM
Do you know if the problem was logged in the DotNetNuke bug tracker?  If so, do you know the number?  We can check to see if the problem has been fixed.
2010-01-03 03:25 PM
As far as I have informed myself and also tried out: In the settings of the module the cache time should be set to zero. It works, but I worry about possible later upgrades, the people say that 5.2.1 has also some bugs, I still don't know which bugs? Until the 5.2.2 is been released and proofed may take a long time, will I have to change the chache again after a possible upgrade?
2010-01-03 04:43 PM
You can look at support.dotnetnuke.com if you want to find bugs or other issues in DotNetNuke.  The list can be searched by version.
