Orizonti vs. Novus ?
Last Post 2009-12-27 05:36 PM by gbrown. 1 Replies.
tcseUser is Offline
2009-12-25 03:01 PM
Hello Lee, Great tutorial on setting up and using Orizonti, I went to snowcovered.com and started looking at other RSS feed readers and also found "Novus" by "OnyakTech" Novus seems to be pretty nice module also, just wondering if you have tested it also. On the demo site www.NewVus.com they are pulling in RSS feeds from DNNCreative, so I wasn't sure if you had tested w/ this mod or not? Also by looking at www.Orizonti.com website there has not been a product update since march of 2006. Are they still in business, or is the Orizonti Module just that Darned Good!
gbrownUser is Offline
2009-12-27 05:36 PM
I have the Orizonti RSS module. I also have the Xmod RSS module.
But I think the best RSS module is now the News Article module from Ventrian. They added the ability to import RSS feeds about a month ago. Very cool - everything is templateable, your users can add comments to each RSS article, you can mix RSS articles with your local site articles/announcements, the News Articles module imports RSS articles to a table in your database and the import runs off of the DNN scheduler so RSS feeds should run much faster than the traditional method, etc.
