how to move Viewstation code down of sourc code
Last Post 2010-02-18 05:55 AM by ashishshukla. 5 Replies.
moradUser is Offline
2009-12-19 12:26 PM
hi lee,Joseph just I wondering about how we can move the viewstation code down of source code I see some of dnn web sites do that for seo Search engine optimization I try to figure out but I didn’t find any usefully article so please help us to know how we can change it to appear the down of source code ?as well how we can compressed to be small size in the source code I will appreciate that’s so much ?
2009-12-20 03:45 AM
Take a look at Pure CSS SEO Layouts for DotNetNuke skins.
For more information regarding DotNetNuke and SEO, check out seablick.com.
2009-12-20 08:07 AM
The pure CSS SEO layout will help for SEO but not for viewstate.
To move the viewstate use Snapsis PageBlaster - this will also provde other performance benefits.
2009-12-20 03:47 PM
I did some Googling about this topic ...
You will find some interesting discussions involving folks like Joe Brinkman and Mitchel Sellers on this topic.
I'm also reminded that there is a new "relocation widget" in DotNetNuke 5.  It will let you move items around in the page.  You can read Will Strohl's take about it here.
ashishshuklaUser is Offline
2010-02-18 05:49 AM
Please ignore this.
2010-02-18 05:55 AM
Hello Sir,
We have a DNN website with community version. We are getting a very big View State in DNN page.
So to remove viewstate at the bottom of page we override render method in Default.aspx.vb in my DNN website as following :
Protected Overrides Sub Render(ByVal writer As System.Web.UI.HtmlTextWriter)
Dim stringWriter As New System.IO.StringWriter()
Dim htmlWriter As New HtmlTextWriter(stringWriter)
MyBase.Render(htmlWriter)
Dim html As String = stringWriter.ToString()
Dim StartPoint As Integer = html.IndexOf(" If StartPoint >= 0 Then
Dim EndPoint As Integer = html.IndexOf("/>", StartPoint) + 2
Dim viewstateInput As String = html.Substring(StartPoint, EndPoint - StartPoint)
html = html.Remove(StartPoint, EndPoint - StartPoint)
Dim FormEndStart As Integer = html.IndexOf("</form>") - 1
If FormEndStart >= 0 Then
html = html.Insert(FormEndStart, viewstateInput)
End If
End If
writer.Write(html)
''MyBase.Render(writer)
End Sub
With this change I am getting the view state at the bottom of the page. Because of this change in Admin/host mode "Control Panel" of DNN is not working.
And I are not able to perform Control Panel options like add page, remove page, add module to a page, etc..
Can you please suggest something on this?
Thanks in Advance.
Ashish Shukla
