Form And List XSL Problem
Last Post 2010-05-14 06:23 AM by Lee Sykes. 5 Replies.
PhilUser is Offline
2009-12-18 04:33 PM
Hi there, this is really confusing me but I cannot find a way to apply xsl styling to the form and list module when in "form" mode, the options only appear whilst in "list" mode.
Is there any way to style up a form?
cube consultingUser is Offline
2010-05-12 08:54 PM
Phil,
Did you manage to get an answer to your question? I am struggling with the same question and find there is little information about the forms and list module..
Aad
aad@cubeconsulting.nl
2010-05-13 01:17 PM
Have you look at the User Manual for the module?
2010-05-13 09:12 PM
Hi Joe, yes I actually read it front to back but there was very little on forms in it at all.. I read in comments from Stephen Cullmann on his blog that css abilities are still very limited. I would like to put more than one form item on the same line and that I just can not seem to do. Other 3rd party modules have not convinced me they can, either. I just want to create a simple contact form, it can't be this hard?! Thanks Aad
2010-05-14 12:58 AM
Stefan Cullman is the lead developer of the Form & List module so what he says should be given great weight.
I believe that both Dynamic Forms and Form Master will do what you need.
2010-05-14 06:23 AM
