Apostraphes showing up as Question marks
Last Post 2009-12-14 01:23 PM by Patrick Ryan. 7 Replies.
Patrick RyanUser is Offline
2009-12-07 08:43 PM
This is driving me insane.
On my site, the apostraphes keep showing up as "?"
If I edit content in the module.. they are fine.. Nothing special in the code.. just straight text.. Then I click save and it's fine for a while.. Then a day later or so, they are all question marks again. It's driving me insane!!
Any help would be greatly appreciated.
Patrick
2009-12-09 08:41 AM
that sounds really strange, what is in the source code for a page when it has changed to to ? do they display as '
Can you give us a URL to an example page that is displaying ?
2009-12-09 03:17 PM
Well, I think I figured out the problem but I still don't fully understand. The Text/HTML modules .. I copied content from Adobe InDesign and pasted it into the modules. Even looking in source mode I see NO formatting issues what-so-ever.
So I don't know how hidden characters could have "snuck" in.
To fix the problem I deleted all of the HTML/TXT modules, and created new ones and typed everything in again without copy/pasting from InDesign.
I don't understand this problem fully, but I wish that I did in case it comes back!
So I can't show a URL either since I fixed the problem..
This is still an issue though if you g uys have any ideas as to a fix.
2009-12-09 03:24 PM
If you are copying and pasting, try using the copy as notepad button in the FCKEditor - this strips out everything except the text - very useful if pasting from word docs, so it should also work for InDesign
2009-12-12 03:02 AM
I wonder if this issue is related.
2009-12-12 08:05 AM
Interesting, thanks for info Joe
2009-12-12 08:20 PM
I just applied Sebastian's fix to a 5.2.0 site that showed copyright symbols a question marks. After running the SQL script, clear the cache and restart the application on the Host Settings page.
2009-12-14 01:23 PM
So is this the issue then? It seems? Interesting.
