Solpartmenu fixed width Mozilla
Last Post 2009-12-09 09:29 AM by Lee Sykes. 4 Replies.
HeinrichUser is Offline
2009-12-07 01:00 PM
<!--[if gte mso 9]> Normal 0 unctuationKerning/> false false false oNotPromoteQF/> EN-ZA X-NONE X-NONE ontGrowAutofit/> ontVertAlignCellWithSp/> ontBreakConstrainedForcedTables/> ontVertAlignInTxbx/> MicrosoftInternetExplorer4 <!-- /* Font Definitions */ @font-face {font-family:"Cambria Math"; panose-1:2 4 5 3 5 4 6 3 2 4; mso-font-charset:1; mso-generic-font-family:roman; mso-font-format:other; mso-font-pitch:variable; mso-font-signature:0 0 0 0 0 0;} @font-face {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4; mso-font-charset:0; mso-generic-font-family:swiss; mso-font-pitch:variable; mso-font-signature:-1610611985 1073750139 0 0 159 0;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-unhide:no; mso-style-qformat:yes; mso-style-parent:""; margin-top:0cm; margin-right:0cm; margin-bottom:10.0pt; margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:Calibri; mso-fareast-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi; mso-fareast-language:EN-US;} .MsoChpDefault {mso-style-type:export-only; mso-default-props:yes; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:Calibri; mso-fareast-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi; mso-fareast-language:EN-US;} .MsoPapDefault {mso-style-type:export-only; margin-bottom:10.0pt; line-height:115%;} @page Section1 {size:595.3pt 841.9pt; margin:72.0pt 72.0pt 72.0pt 72.0pt; mso-header-margin:35.4pt; mso-footer-margin:35.4pt; mso-paper-source:0;} div.Section1 {page:Section1;} --> <!--[if gte mso 10]> I have been spending the last 3 days trying to resolve this issue so please help me.
I am using the Solpartmenu horizontally with a fixed width td, but I am not sure if Mozilla doesn’t want to wrap the text, or if Mozilla just doesn’t want to stick to the width.
My ASCX code:
<dnn:MENU runat="server" id="dnnMENU"
          useskinpatharrowimages="true"
          rootmenuitemcssclass="MainMenu_RootMenuItem"
            rootmenuitemactivecssclass="MainMenu_RootMenuItemActive"
            RootMenuItemSelectedCssClass="MainMenu_RootMenuItemSelected TD"
            UseRootBreadCrumbArrow="false"
            RightSeparator=""
            rightseparatoractive=""
            submenuitemactivecssclass="MainMenu_SubMenuItemActive"
            submenuitemselectedcssclass="MainMenu_SubMenuItemSelected"   />
My CSS:
/* Main Menu */
.MainMenu_MenuContainer {
      background-image: url(images/menu_normal_backgound.jpg);
      background-position: top;
      padding:0px 0px 0px 0px;
      background-color: Black;
.MainMenu_MenuBar {
      cursor: pointer;
      cursor: hand;
      height: 62px;
.MainMenu_MenuItem {
      border: solid 1px #2b2b2b;
    background-color: #949292;
    height: 31px;
    width: 146px;
      padding: 5;
      cursor: pointer;
      cursor: hand;
      color: white;
      font-family: Tahoma, Arial, Helvetica;
      font-size: 10pt;
      font-weight: normal;
      font-style: normal;
      text-align: center;
.MainMenu_MenuItemSel {
      border-left: #2b2b2b 1px solid;
      border-bottom: #2b2b2b 1px solid;
      border-top: #2b2b2b 1px solid;
      border-right: #2b2b2b 1px solid;
      background-color: #00a3fa;
.MainMenu_MenuIcon      {
    display: none;
.MainMenu_SubMenu {
      z-index: 1000;
      cursor: pointer;
      cursor: hand;
.MainMenu_MenuBreak {
      height: 0px;
.MainMenu_RootMenuItem TD {
      cursor: pointer;
      cursor: hand;
      color: #858484;
      font-size: 10pt;
      font-style: normal;
      text-align: center;
      text-transform : uppercase;
      background-color: Transparent;
      width: 156px;
      height: 62px;
.MainMenu_RootMenuItemActive TD {
      cursor: pointer;
      cursor: hand;
      color: white;
      font-size: 10pt;
      font-style: normal;
      text-align: center;
      width: 156px;
      height: 62px;
      background-image: url(images/menu_over_background.jpg);
.MainMenu_RootMenuItemSelected TD {
      background-repeat: repeat-x;
      cursor: pointer;
      cursor: hand;
      color: white;
      font-size: 10pt;
      font-style: normal;
      text-align:center;
      text-transform: uppercase;
      width: 156px;
      height: 62px;
.MainMenu_SubMenuItemActive {
    height: 31px;
    width: 146px;
.MainMenu_SubMenuItemSelected {
    height: 31px;
    width: 146px;
.MainMenu_MenuArrow {
    display: none;
.MainMenu_RootMenuArrow {
      display: none;
I thank you in advance.
2009-12-07 01:02 PM
The url to the website is http://www.cnetworking.co.za
2009-12-09 09:04 AM
have you fixed this issue? When I view the menu in Firefox, each menu item is a fixed width and the text wraps.
2009-12-09 09:24 AM
Yes I have. I added the following to the td
white-space: pre-wrap; /* css-3 */
white-space: -moz-pre-wrap; /* Mozilla, since 1999 */
white-space: -pre-wrap; /* Opera 4-6 */
white-space: -o-pre-wrap; /* Opera 7 */
word-wrap: break-word; /* Internet Explorer 5.5+ */
2009-12-09 09:29 AM
thanks for the info
