FREE DNN Power Login module
Last Post 2009-12-07 10:10 AM by codingstaff. 0 Replies.
codingstaffUser is Offline
2009-12-07 10:10 AM
    Coding Staff is proud to announce a release of DNN Skins and DNN Power Login module version 1.00.03
    Power Login is a free dnn module that replaces standard dotnetnuke login module with custom authentication and CSS based layout. As opposed to standard dnn login Power Login by Coding Staff provides web designers with skinning flexibility. Please don't hesitate to discuss this module via DotNetNuke Forum, Snowcovered or directly contact Coding Staff.
    Coding Staff - cutting edge dotnetnuke module development and dotnetnuke skinning.
