Replacing FCK Editor
Last Post 2009-12-09 09:18 AM by Lee Sykes. 1 Replies.
h2xUser is Offline
2009-12-07 04:11 AM
I am wondering if anyone has any recommendations about replacing the FCK editor? When I first started using DNN a few years ago, I customized the editor for my sites and this was an okay solution. On my most recent project I purchased CuteSoft's .net editor for DNN. Although I really like this editor, I was not at all happy with their tech support/customer service and am starting to have real doubts about the legitimacy of the company. Regardless, I am not starting a new project and wonder if I should just costumize the FCK editor again or purchase another solution?
Thanks so much!
2009-12-09 09:18 AM
if it was a few years ago when you customise the FCK editor, you may find that the latest version of the FCK editor is more compatible and you do not need as much customisation.
Your other option would be to look at Telerik
DNN nav issue by imran shaikh
