Restricting User Profile Settings
Last Post 2009-12-09 09:23 AM by Lee Sykes. 1 Replies.
ChrisUser is Offline
2009-12-07 02:34 AM
Does anyone know if there is a way to restrict Users from changing some of the their User Profile Settings? I've added some custom fields that I want to assign members of a Security Group in charge of changing these User settings because they require proof, but I want the User to be able to verify that the dates are correct.
2009-12-09 09:23 AM
I'm not sure how you would do this with the core registration, however you may be able to achieve this using modules such as datasprings dynamic series, I would contact their support and see if they have a suggestion on how it can be configured:
http://www.datasprings.com/Products...ation.aspx
