Does this work with Aweber?
Last Post 2009-12-06 04:03 PM by James H. Byrd. 2 Replies.
Nazarene IsraelUser is Offline
2009-12-06 02:01 AM
2009-12-06 02:04 AM
The website says that it does. I've never used it.
James H. ByrdUser is Offline
2009-12-06 04:03 PM
Yes, the tool was designed specifically for AWeber. The site has two articles that relate to it:
The "Posting to an Off-Site Page in DotNetNuke" article explains how the tool works:
http://www.nerdymusings.com/LPMArti....asp?ID=20
The "Embedding Forms in an ASP.NET Web Page" explains the theory behind the process and shows how you can apply it to any situation where you need to post a form to a web site hosted elsewhere (e.g. for PayPal buttons).
http://www.nerdymusings.com/LPMArti....asp?ID=27
If you still have questions or need additional help, please post it through the contact page on the Nerdy Musings site so I'll be sure to get it. I only saw your query here because of a Google Alert.
James Byrd
Contributing Editor
NerdyMusings.com
