DNN5 custom registration page
Last Post 2010-06-04 12:45 PM by Joseph Craig. 22 Replies.
Page 2 of 2 << < 12
VikUser is Offline
2010-06-04 03:43 AM
We need to use our DNN web site and login to external db using web services. The same with Registration process and password change. 1. I copied and modify existing DNN Auth folder (renamed it) and installed it as extension to Authentication. I will modify code to be able to login through web services now. Would it work? 2. I can not find anywhere in the latest version of DNN, that I downloaded, Register.ascx file in my Visual Studio project. Where is it? Can I create the same file (if I find it) as a new extension and modify code to use web services?
2010-06-04 12:42 PM
Yes, I think that you are moving in the right direction.
There isn't a "Register.aspx" but there is a Login.ascx that is part of the authentication package (from memory) that contains the registration part.  If you cannot find it ask me again and I'll look through the code.
2010-06-04 12:45 PM
Whoops:  Desktop Modules/Admin/Authentication contains the Registration part.
Page 2 of 2 << < 12
RE: Deploying dnn by Sameer
Just sent it.
