Search module not working
Last Post 2009-11-22 04:54 AM by Joseph Craig. 1 Replies.
Pankaj1User is Offline
2009-11-19 02:09 PM
Hi , I am using dont net nuke 4.9 version. I have added dnn tag for search module inside skin .but still my search module is not working . Please help me.
2009-11-22 04:54 AM
There is a scheduled task that must be running for the search to return results.
DNN nav issue by imran shaikh
