DNN Blog: "No Entries were posted for this blog."
Last Post 2009-11-19 11:37 AM by SixfootStudio. 1 Replies.
SixfootStudioUser is Offline
2009-11-19 11:02 AM
Hi Guys,
I have my blog working with multiple sub blogs. I can add entries to these blogs and save them but when I view the the blogs they don't show unless I do a search on all the blogs (leaving the search field blank show all my blog entries)
Is there some kind of publish setting, role issue or visibility issue that I am not aware of for this?
Cheers,
James
2009-11-19 11:37 AM
Turns out you cannot publish the entry on the same date!!! That's crazy and a bug they should sort out.
Anyway, set the date to the previous day and it will publish
DNN nav issue by imran shaikh
