Problem with DateEditControl
Last Post 2009-10-29 09:59 AM by Carlo. 0 Replies.
CarloUser is Offline
2009-10-29 09:59 AM
Hi to everyone,
i've a problem with the DateEditControl. I'm working on a page that contains one control of this type. When i try to get its value
(after an "Insert" Button is pressed) i always find the "1/1/0001" value ...
Tha source code is something like
DateTime DateTimeToInsert = new DateTime;
DateTimeToInsert =(DateTime) DateEditCntrl.Value;
where DateEditCntrl is a DateEditControl
Can someone help me?
Carlo
DNN nav issue by imran shaikh
