Encoding a hebrew page
Last Post 2009-07-13 07:12 PM by Lee Sykes. 1 Replies.
Alejandro KuznerUser is Offline
2009-07-12 09:05 PM
Hi, i have a dotnetnuke 4.94 application and i have problems with some modules to show hebrew. Where I can change the encoding of the dotnetnuke application?
2009-07-13 07:12 PM
Do some modules display hebrew and others do not?
You may find that some modules do not have localization enabled, you can check this however by going to the admin menu / languages
Click on language editor
Expand Local Resources / Desktop Modules
Inside there you will see the language files for each module.
