Copying module to multiple pages
Last Post 2009-07-12 02:02 PM by Joseph Craig. 1 Replies.
Oscar ImUser is Offline
2009-07-11 06:25 PM
Is there a way to copy a module to several pages?  I know that you can specify to display a module on all pages or on all new pages but that does not suit my need.
Specifically, I want to create a links module that has links to ~30 pages within my site.  I then want to place that module on each of those 30 pages.  I'm hoping that I don't have to create the module individually.
Thanks in advance.
Oscar
2009-07-12 02:02 PM
