DNN eventscalender module ...Doubt
Last Post 2009-07-13 07:22 PM by Lee Sykes. 1 Replies.
dnnkUser is Offline
2009-07-11 04:22 PM
Friends, I have installed the dnn events calender. My questions are, 1. Does the Eventscalender module allow the users to schedule for interactive reminders for appointments, and activities of daily living? 2. I dont see an option " add event" when i login as a user. Can I create any appointments as user and set the reminders? If No, Is there any module which does these things? Thanks in advance
2009-07-13 07:22 PM
You can give users edit permissions and moderator permissions.
Go to the settings of the event module menu
Under permissions tick 'edit modules' for registered users, anyone with a username will then have permission to add events.
If you wish you can also set it up to require moderation - on the same page at the bottom expand the event module settings section.
