Dnn Tabs in ASP 3.0 web app
Last Post 2009-07-13 12:26 AM by Alberto Mendia. 2 Replies.
Alberto MendiaUser is Offline
2009-07-10 06:49 PM
I have a developed an application with ASP 3.0 and I want to add within links to pages made in Dotnetnuke that they contain developed modules with OWS.
Which is the form advisable in order to do this?
Should I create a portal that does not require authentication and to add to this portal so many pages DNN as needs?
2009-07-11 02:17 AM
You can certainly add links to a DotNetNuke site in your ASP site. You can't easily mix ASP pages and DotNetNuke within a single website.
2009-07-13 12:26 AM
Ok, Thanks Joe.
