howt to calculate page hit count?
Last Post 2009-07-10 01:14 PM by Joseph Craig. 1 Replies.
SakthiUser is Offline
2009-07-10 07:45 AM
Can any one know how to calculate page hit count in DNN?
Is there any inbuild module or existing module?
or
if we need to create a custom module then how?
Thanks in advance!
2009-07-10 01:14 PM
Do you want to show a counter on the page? If so, there are several modules available. I'd look first on snowcovered.com.
For general statistics, I prefer Google Analytics.
