Login box on homepage
Last Post 2009-07-10 01:17 PM by Joseph Craig. 1 Replies.
ashioUser is Offline
2009-07-10 06:55 AM
Is it possible to have the login and password box on the homepage, so members can type in their details and login in straight away, instead of clicking on the login in link (taking to separate page to login)?
2009-07-10 01:17 PM
Yes, just add the Account Login module to the page.
If you set it to be visible only to Unauthenticated Users, it will disappear when someone has logged in.
