Music Publications Store Module?
Last Post 2009-07-10 11:26 AM by Lee Sykes. 1 Replies.
markhpUser is Offline
2009-07-09 09:22 AM
I am fairly new to DNN, and have started using the Store module. I'm developing a site for a music publisher in the UK, and I want to be able to list publications in the following ways: Category > Sub-Category > Composer > Titles Composer > Category > Sub-Category > Titles Is there a third-party store module which I can use to achieve this out of the box, or will I have to modify an existing module or develop something entirely new? Any advice would be very much appreciated.
2009-07-10 11:26 AM
Most store modules will allow you to specify any of the categories you require. You can have a look at some module reviews here:
Issue 30 - Ecommerce, Store Module, PayPal Sandbox, Store Module Reviews
I would also recommend you have a look on snowcovered.com
DNN nav issue by imran shaikh
