Module Package
Last Post 2009-07-09 01:05 PM by Joseph Craig. 1 Replies.
SakthiUser is Offline
2009-07-09 09:10 AM
I created a new module, with new table and I added new methods in ASPNETmembership provider to get the values from the table (DotNetNuke.dll). It is working fine in the local place.
When I created a Module package, how should I reflect this in module package?
I am able to create a module package, when installing the same module in another instance i am able to install it. While adding the module to page, it is showing error in aspnetmemebership provider not availbale.
Please help anyone to solve this issue?
My requirement is : Create module and display the information the SQL table.
Is there any other way to achieve this?
thanks
2009-07-09 01:05 PM
Adding methods to the Membership Provider may not be the way to go. It's better to create a data provider for the module.
The error message indicates a problem with the membership provider, but it's not clear what is the problem.
I'd recommend that you use Mitchel Sellers' book on DotNetNuke Module Development as your textbook for learning how to create modules.
DNN nav issue by imran shaikh
