Module Wrapper & Tab Aggregator??
Last Post 2009-07-05 08:47 AM by Lee Sykes. 2 Replies.
gbrownUser is Offline
2009-07-03 07:47 PM
Has anybody tried to place a Module Wrapper module from ZLDNN inside a Tab Aggregator module from DNNStuff??
Looking for a solution to place modules side-by-side inside of a tab in Tab Aggregator.
Greg
2009-07-03 11:42 PM
Found the Ajax Module Wrapper from Gumbosoft. Bought it and tried it - it works inside of Tab Aggregator.
Greg
2009-07-05 08:47 AM
ok great, thanks for letting us know
RE: DNN 6.2 by Joseph Craig
DNN 6.2 by Sameer
RE: Deploying dnn by Sameer
Thanks a lot so kind of you
