How to prevent auser from multiple login.
Last Post 2009-07-03 04:24 PM by Joseph Craig. 1 Replies.
Imran HameedUser is Offline
2009-07-03 08:21 AM
Is there any way to prevent a register user from multiple login at the same time in the DNN.?
2009-07-03 04:24 PM
