From where to switch off Site & Event log
Last Post 2009-07-02 11:10 AM by Joseph Craig. 1 Replies.
sharadUser is Offline
2009-07-02 10:05 AM
Please let me know from  where to switch off (un-check) Site & Event log.
Regards
Sharad
2009-07-02 11:10 AM
There are settings on both the Host Settings and Site Settings pages that control how much is retained in the Site Log.
On the Event Log you can determine which items are logged and how many are saved.
See Site logs, Event logs and Scheduler for more.
DNN 6.2 by Sameer
RE: Deploying dnn by Sameer
Thanks a lot so kind of you
I'm confused by this, too.
We are running DNN 6.x
