FCKeditor
Last Post 2009-07-02 04:42 PM by mkk. 2 Replies.
mkkUser is Offline
2009-07-01 09:38 PM
HI, i am facing problem with FCKeditor, i want certain role of people to allow permisions to upload image file, right now i see only admin can do that. some one give some idea Thanks
2009-07-01 11:17 PM
go to the admin menu / file manager
And in there you can specify which security roles have permission to upload files, for further information:
DotNetNuke File Manager
mkkUser is Offline
2009-07-02 04:42 PM
thanks lee, i got that...
