Are You Usinf iFinity Moudle on DNN Creative?
Last Post 2009-07-01 08:51 PM by Lee Sykes. 1 Replies.
mgordonUser is Offline
2009-07-01 06:28 PM
Hi Guys!
I've just downloaded your tutorials for using the iFinity module, but I'm wondering if you use it on DNNCreative, and if not, why?
Mark
Mark Gordon
Webmonkey
2009-07-01 08:51 PM
I currently do not use iFinity URL master module on DNN Creative quite simply because it scares me changing all the urls on the site when it is listed ok in the search engines. - I have made changes in the past for rankings where the change should have improved the rank but it's actually reduced the rank. - so, I'm not going to risk it with DNN creative, even though in theory everything should work out fine and even improve rankings due to the 301 redirects.
However, I have used this module on several new websites since creating the tutorial and any future websites I create will be using the module.
