News feed (RSS) update problem
Last Post 2009-07-02 12:05 AM by Knut Erik. 2 Replies.
Knut ErikUser is Offline
2009-06-28 09:55 PM
Hello, I'm trying to get a News Feed (RSS) module to read content from an Announcements module on my site. The News Feed is version 03.01.01. This seems to work, but sometimes it takes a really long time for the News Feed module to update. Also, it shows content that I deleted ages ago. I am not so familiar with this module, so I don't know where to set the update time. There is a cache time setting under Module settings, but not under Edit Newsfeed. Any advice is highly appreciated Best regards, Knut Erik
2009-07-01 09:58 PM
For better performance, I would recommend you use this module: Orizonti Nuke Feeds - full module spec on that page
2009-07-02 12:05 AM
Thanks, but I have discovered that the problem is the Announcements module rather than the News feed module. Syndication is not working properly for Announcements, it displays content I deleted a long time ago. I have another thread on this issue. Thanks, Knut Erik
DNN nav issue by imran shaikh
