How to apply robots.txt file on DNN web site
Last Post 2009-06-16 02:34 PM by Joseph Craig. 1 Replies.
Imran HameedUser is Offline
2009-06-16 12:28 PM
I have a site http://www..ie . It has a folder /Portals/1/MyFolder.
I do not want any search engine to index any URL containing the string '/portals/1/MyFolder'.
My robots.txt file is on the root of my DnnWebSite. My Robots.txt file contains the contents as
User-Agent: *
Disallow: /Portals/1/MyFolder/
Will robots.txt work for the DNN web Sites? Or is there any other way to do this.
Thanks in advance
2009-06-16 02:34 PM
Yes, robots.txt will work for DotNetNuke sites.
DNN nav issue by imran shaikh
